powerband
arena314
hey guys.. so due to an extremely busy summer I havent been able to get my bikes out for any good riding. pulled the banshee out on the 4th of July just to see if she was still running good. idles and revs great but wasnt hitting the band it would kinda just break up so I though its probably time to go through the carbs again since it's been sitting. after cleaning the carbs it ran great put it back and then once again it sat till this weekend. took it out and it ran good then I pulled the seat off and remembered I pulled the filter off to clean it and didnt put it back in yet I only rode it up the street so it should hopefully be fine. well I tried riding it and it was breaking up again. I decided to spray out the carbs again but instead of fully pulling them out I just kinda tipped them to the side pulled the bowls off and sprayed them out. I did see I bit of little black speckles at the bottom of the bowls in the fuel. after doing a quick spray I realized it fixed nothing it's still breaking up kinda in the mid rpm then it tries clearing out at high rpm but doesnt. I tested the stator and got 9.8 ohms on the ignition coil and 123 ohms on the pickup coil. the 9.8 ohms on the ignition coil seems a little out of spec to me but could this he causing this type of issue? or do you think I should completely disassemble the carbs and clean them right? thanks guys lmk. banshees dont like sitting lol
Sent from my SM-G965U using Tapatalk
