jason.perez Posted September 4, 2019 Report Share Posted September 4, 2019 (edited) 97 shee Toomey t5’s uni pod’s no tors I’m at 300 ft also ride at 3000 Stock VM26’s carbs have 330’s in them right now, should be kind of rich right ? stock needles, but I also have Vito’s RED needles Idk if that will work better? Pilots 30. 1.5 turns out idles perfect the bike runs fine on low end but once I start getting higher in the Rpms it feels weird, the power band laggs to kick in, in second it takes even longer, then third can’t really hit it and so on. Any suggestions ? Also could it be float Height? And how much does an exhaust leak effect performance ? Sorry a lot of questions I also have mains from 290-350, if u guys suggest I change the pilots I have to order but my problem is at WOT (Don't want to go to 3000 ft until I can get it right then when I ride up there I can just switch out mains) Edited September 4, 2019 by jason.perez Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 4, 2019 Report Share Posted September 4, 2019 Use the vitos needles. stock pilot and 290 300 main should be good going into fall. try needle in the middle or 4th clip. lean it out until it cleans up as it transitions into the powerband Quote Link to comment Share on other sites More sharing options...
jason.perez Posted September 4, 2019 Author Report Share Posted September 4, 2019 Thank you do you think I could run the 30 pilots until I figure out the main ? Because I gatta order those. The 30 feels good tho the 1/4 response is clean maybe 27.5? You would know more Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 5, 2019 Report Share Posted September 5, 2019 yes just adjust the air fuel screw accordingly Quote Link to comment Share on other sites More sharing options...
jason.perez Posted September 5, 2019 Author Report Share Posted September 5, 2019 Thanks she’s finally trying to rip me off with that 310 jet 2 Quote Link to comment Share on other sites More sharing options...
jason.perez Posted September 6, 2019 Author Report Share Posted September 6, 2019 I ended up with the 290 main. When I go up to 3000 ft should I bump up to 300 or 310. And do you think I’ll have to mess with the needles, I know u can’t really tell cuz ur not on it but just from experience Quote Link to comment Share on other sites More sharing options...
trumanbuckley1 Posted January 12, 2020 Report Share Posted January 12, 2020 Hello, I have a very similar banshee setup with T5’s, pods, +2° timing, TORS, stock carbs, Toomey needles, my jetting at 900ish ft above sea level is 25 pilot, 310 mains (I’m still 1 jet just above where I could be, but left it slightly rich for peace of mind) and the needle on the 4th notch. On my particular engine it really liked that setup and on a 60° day pulled very strong for what it is. I don’t have any pics of my plugs but I could take some if you want. Here’s a pic of the dyno graph Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 17, 2020 Report Share Posted January 17, 2020 On 9/6/2019 at 6:50 PM, jason.perez said: I ended up with the 290 main. When I go up to 3000 ft should I bump up to 300 or 310. And do you think I’ll have to mess with the needles, I know u can’t really tell cuz ur not on it but just from experience When you go up in elevation, you actually should be actually be using less fuel as the air is less dense. More then likely you can use the 290, but if it acts all blubbery you can drop it down to 280. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted January 17, 2020 Report Share Posted January 17, 2020 On 1/11/2020 at 8:26 PM, trumanbuckley1 said: Hello, I have a very similar banshee setup with T5’s, pods, +2° timing, TORS, stock carbs, Toomey needles, my jetting at 900ish ft above sea level is 25 pilot, 310 mains (I’m still 1 jet just above where I could be, but left it slightly rich for peace of mind) and the needle on the 4th notch. On my particular engine it really liked that setup and on a 60° day pulled very strong for what it is. I don’t have any pics of my plugs but I could take some if you want. Here’s a pic of the dyno graph Sent from my iPhone using Tapatalk That thing could definitely use a little more pilot. Quote Link to comment Share on other sites More sharing options...
