Tactical Bacon Posted August 27, 2019 Report Share Posted August 27, 2019 New to the Banshee scene, but talked to some engine builders and they are saying that stock cranks are wear items and if I am going to port/ make more power, I should be replacing that 20yr old worn out crankshaft. Are they really a wear item? Motor isn't ragged out, but does have some time on it for sure. I am going to have it bored and ported while I have it out. And I do have to split cases and replace seals, but the crank wasn't on my list. Maybe it should be, what do you think? Vito's 350HP seems the way to go, but not sure. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted August 27, 2019 Report Share Posted August 27, 2019 I would replace/rebuild it. Have welded and balanced/trued Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted August 27, 2019 Report Share Posted August 27, 2019 That was good advice that you were given. Vitos 350hp? what is that. Im assuming your talking about crank shaft? Driveline performance makes great crank shafts as well at an affordable price. All assembled, welded and trued in house. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 27, 2019 Report Share Posted August 27, 2019 Vito's= rattle can ray...DONOTSent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
97Screamer Posted August 27, 2019 Report Share Posted August 27, 2019 +1 for Vitos is junk. Don't buy anything from them, listen to whoever told you to replace the crank, and enjoy your banshee.Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tactical Bacon Posted August 28, 2019 Author Report Share Posted August 28, 2019 I will be looking into the Driveline crank, haven't heard of them before. Thanks. I had read where some of the people on BansheeHQ were only running Vito stuff because they thought it was the best or hadn't had any issues with their cranks. The 350HP from Vito's is their higher end standard crank, with koyo bearings, coated rod bearings, etc. Have no experience with any of the companies so looking for any pointers Quote Link to comment Share on other sites More sharing options...
gusto Posted August 28, 2019 Report Share Posted August 28, 2019 there is a stock stroke hot rods for sale right now in the FS section. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 2, 2019 Report Share Posted September 2, 2019 Rebuild it all. Driveline crank is a good start. Quote Link to comment Share on other sites More sharing options...
registered user Posted September 2, 2019 Report Share Posted September 2, 2019 On 8/27/2019 at 4:40 PM, Ayesully810 said: That was good advice that you were given. Vitos 350hp? what is that. Im assuming your talking about crank shaft? Driveline performance makes great crank shafts as well at an affordable price. All assembled, welded and trued in house. unless something has changed, crankworks is the only shop to make the components in house. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 3, 2019 Report Share Posted September 3, 2019 21 hours ago, registered user said: unless something has changed, crankworks is the only shop to make the components in house. not what i said Quote Link to comment Share on other sites More sharing options...
registered user Posted September 3, 2019 Report Share Posted September 3, 2019 u said driveline makes great crankshafts. they dont make any part of the crankshaft. just so the less informed folks dont get confused Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 3, 2019 Report Share Posted September 3, 2019 they wont be Quote Link to comment Share on other sites More sharing options...
