jason.perez Posted August 27, 2019 Report Posted August 27, 2019 Is it even possible to run these huge 34mm flatslide carbs on a almost stock banshee. Or get it to run close to decent. If so what’s jets and needles should I be running at 300ft with Toomey t5’s and uni pods Quote
375hp banshees Posted August 27, 2019 Report Posted August 27, 2019 You can, but it's a waste, but if that's all you have? you're going to lose some bottom end and won't be ideal , but you can tune it to run okay Quote
jason.perez Posted August 27, 2019 Author Report Posted August 27, 2019 Like will it barely be a noticeable difference or u could diffenatly tell? Also have a pair of vm26-606 there close to oem but not it. The needle jets are different they screw in. Ive tried all the way from 320 to 350 mains didnt really make a diffence the bike wouldnt hit the power band ive tried all needle clip positions (red vitos jet needle) and still only hits powerband in first and very late. almost like a rev limiter hits but i have no parking brake and tors box is unplugged. So i was wondering if those carbs would work thats all i got right now. Quote
