Derek_b23 Posted August 16, 2019 Report Posted August 16, 2019 I have a stock bottom end with Paul turner jugs mid range for mx and I know have a lot of porting done and need help on a good starting point to jetting he’s my set up paul turner midrange jugs vitos cool head 22cc domes vforce 4 reeds 34mm keihin style carbs stock air box with kn filter 480ft above sea level Quote
97Screamer Posted August 16, 2019 Report Posted August 16, 2019 Those carbs are going to cause more headaches than they're worth. The PJ wasn't a great design to tune and being knock-offs makes it worse. With that said your probably going to be in the 145/45 range on jets. Type of pipes will also play into this. I'd start two sizes higher on both and work your way down. Quote
Derek_b23 Posted August 16, 2019 Author Report Posted August 16, 2019 Okay I appreciate the advice I’ll eventually get some better carbs but for now this is what I was able to get together! I’ll start with this and hope I can dial it in! Quote
laflair23 Posted August 21, 2019 Report Posted August 21, 2019 hey do you know anything bout the carbs vito performance pck352fik???? Quote
Ayesully810 Posted August 21, 2019 Report Posted August 21, 2019 they are likely fake because ive been seeing a lot of china stuff from them lately like stators carbs etc Quote
ginger Posted August 23, 2019 Report Posted August 23, 2019 get something of the PMK series. they seem to be the most consistent. Quote
Killacaviar Posted August 26, 2019 Report Posted August 26, 2019 I have pwk28s to sell. They would work well with your setup. Sent from my iPhone using Tapatalk Quote
