JG1 Posted October 12, 2019 Author Report Share Posted October 12, 2019 I didn’t choke. Bike felt completely dead until some fuel started getting in the cylinders. I was opening the throttle a bit which I probably shouldn’t do. Thr previous owner said the motor is brand new....less than 5 hours on it. I’m wondering if I should get a compression tester though. You think the wire harness might be bad? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted October 12, 2019 Report Share Posted October 12, 2019 No they're LEDs and you're running them off of AC. verify that you're getting the right power to your lights and then go from thereSent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted October 12, 2019 Author Report Share Posted October 12, 2019 So you think they’re definitely running on AC from what you see? Ill have to get a meter. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted October 12, 2019 Report Share Posted October 12, 2019 On 10/3/2019 at 12:54 PM, JG1 said: I'm going to check the wiring harness tomorrow. Make sure the grounds are grounded and the connections aren't loose. I take a pic of the voltage regulator. Sent from my SM-G960U using Tapatalk Idk this is the last I heard about it...but, if you check it with a meter you'll know & you'll narrow it down to lights or power problem Quote Link to comment Share on other sites More sharing options...
