sheerider11 Posted September 28, 2019 Report Share Posted September 28, 2019 Not much important. Tyler always say :" heavy as fuck", so i want to know how heavy is "heavy as fuck" ;-)Envoyé de mon SM-G965W en utilisant TapatalkJust got these in claude. I will weight them when I swap over. Sent from my SM-G970U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 Swapped out the throttle cable. I feel like I need a little more slack. Its tight. Even with the adjuster at the thumb level screwed all the way in, and the fittings on top of the carbs all the way in. The carb on the right; the slide goes all the way down. The carb on the right; the slide wont bottom down. Also, when I press the thumb lever all the way open, the carbs lift just a hair. Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 29, 2019 Report Share Posted September 29, 2019 Is there another adjuster @ the Y ?Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 No, just a boot at the YSent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 (edited) Should I just tighten the idle screw on the right carb to have the slide sit where the left one does? Or does the left need to come down a bit too? Sent from my SM-G960U using Tapatalk Edited September 29, 2019 by JG1 Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 29, 2019 Report Share Posted September 29, 2019 Looks like you need the longer cable. Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 Jesus ChristSent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 Maybe I'll go back to this cable, and try to grind a little bit off the balls at the end and try to get them to fit through the fittings on the carbs Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 Ok. That worked. Old cable going back onSent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 (edited) The slack is perfect now. Next issue. The end of the throttle cable is threaded. And the top of the fittings on the carbs is no threaded. This piece can slide in and out, which messes up the slack in the cable. Any ideas? I’m not sure if the boot at the end of the cable will hold it in place when I slide it down Sent from my SM-G960U using Tapatalk Edited September 29, 2019 by JG1 Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 Also, how high should these slides sit for idle? Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted September 29, 2019 Report Share Posted September 29, 2019 It’s supposed to be able to slide in and out. That’s normal. Slides need to be synced. Then set idle. Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 29, 2019 Author Report Share Posted September 29, 2019 It’s supposed to be able to slide in and out. That’s normal. Slides need to be synced. Then set idle. Ok cool. Slides are synced. I just have to set the idle. Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted September 30, 2019 Author Report Share Posted September 30, 2019 (edited) Been doing some reading and watching vids. Does this sound right? Air screw, turn all the way in then back out 1 turn. Idle screw, back out all the way, then in until the slide starts moving. Once slide starts moving, turn 2.5 turns in. Edited September 30, 2019 by JG1 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 30, 2019 Report Share Posted September 30, 2019 Iirc usually 1-1/2 turns on air( if jetted correctly) if to far off of that rejet.Set idol to your preferred rpm usually checked with vac. Gauge/ Sync tool to make sure they are sync'd Some set idol with cable & some with screws. then check sync. again at higher Rpms ( or sight in the windows @ wot ; off) to verify sync.Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
