locogato11283 Posted August 25, 2019 Report Share Posted August 25, 2019 http://redlineracing.biz/shop/keihin-35mm-pwk/ Quote Link to comment Share on other sites More sharing options...
Schweet97Z Posted August 25, 2019 Report Share Posted August 25, 2019 If your going 35mm carbs here are the K&N part numbers. Also available at sponsor sites. Loco won’t steer you wrong.33-35mm Carbs - RU-1090 - Pre Filter - RU-0520PK - Filter Dimensions 3.5" x 6" **10 Degree Flange Angle**Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 http://redlineracing.biz/shop/keihin-35mm-pwk/Is that for 2?Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 If your going 35mm carbs here are the K&N part numbers. Also available at sponsor sites. Loco won’t steer you wrong.33-35mm Carbs - RU-1090 - Pre Filter - RU-0520PK - Filter Dimensions 3.5" x 6" **10 Degree Flange Angle**Sent from my iPhone using TapatalkAwesome, thanks!Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 26, 2019 Report Share Posted August 26, 2019 Is that for 2?Sent from my SM-G960U using TapatalkYes. Redline has it priced in pairs. Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 Yes. Redline has it priced in pairs. I'll order today. Do I need to order a jetting kit too?Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted August 26, 2019 Report Share Posted August 26, 2019 I'll order today. Do I need to order a jetting kit too?Sent from my SM-G960U using TapatalkI'd call and talk to him. He may be able to set you up close to where you need to be. We are at sea level Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 I'd call and talk to him. He may be able to set you up close to where you need to be. We are at sea level Sent from my SM-G960U using TapatalkOk will do. Do I speak to someone in particular? Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 26, 2019 Report Share Posted August 26, 2019 Ok will do. Do I speak to someone in particular? Sent from my SM-G960U using TapatalkCameron. Tell him you got the info from Tyler. He will know what you’re talking about. Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 Cameron. Tell him you got the info from Tyler. He will know what you’re talking about. Will do! Thanks!Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 Just got a couple goodies in Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 26, 2019 Author Report Share Posted August 26, 2019 Carbs ordered. I sure hope this resolves the issue. Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 29, 2019 Author Report Share Posted August 29, 2019 Stator cover and shifter Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
JG1 Posted August 29, 2019 Author Report Share Posted August 29, 2019 I just bought this gas cap off Amazon and apparently it's not venting?Defective or I need to adjust it somehow?Sent from my SM-G960U using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted August 29, 2019 Report Share Posted August 29, 2019 Remove the black pc on top. The check valve gets clogged. Those r junkSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
