Clutch problem need help please
Ok so when I pull on the clutch it has pressure. So when I put it in gear and pull on the clutch it won’t let it roll the clutch stays engaged if I tight the screw all the way the clutch gets really hard and it still won’t roll
Also I don’t have enough Thread to put this nut on is this ok11ff736185d191cb767ab985113ea31a.jpg
I'm not familiar with that particular clutch set up, but just by looking at it? Makes me wonder 2 things.. 1.) Is the outer hub clocked in the right position ? 2.) Does the pancake bearing have the correct length set screw for YOUR set up ? If it were me?  Either one would leave you without enough threads for the locking nut. If it were ME ? I would unbolt the outer hub and turn it one bolt hole and see if that fixes it.
Im a dumb ass had to adjust the screw because at first I had no pressure on the clutch lever
.. No worries..we all miss the simple stuff sometimes..
Sent from my LG-H700 using Tapatalk
  • 2 weeks later...
