Shermanracer Posted August 6, 2019 Report Posted August 6, 2019 I recently did some modds.now my banshee won't idle.seems like it's running out of fuel and dieing.ran perfect before with 27.5 pilot and 290 mains.my new modds are. Uni pod filters..v force 4..lightened flywheel..+4timing..dune port with boyesen port holes.. Last year my motor was all rebuilt..worked good.new crank and 80 over wiseco promotes.im running set pipes with shortened silencers.any help would be appreciated. Thanks. Quote
Shermanracer Posted August 6, 2019 Author Report Posted August 6, 2019 Usually takes quite a few kicks Quote
Ayesully810 Posted August 7, 2019 Report Posted August 7, 2019 2 hours ago, Shermanracer said: Usually takes quite a few kicks Try a 30 pilot with the air fuel screw at 1 turn out. Also you might need more main jet unless your riding in really really hot temps right now, But I would go to a 310 to start and see if its too much Quote
