So i have stock size piston and stroke, i have k&n air filter, stock airbox with vents, no snorkle, vforce 4 reeds, T5 headers and stingers, +3 timing, keihin pwk 28 mm, main 145, 48 pilot, needle clip in second position from the pointy end to the top, elevation is 650 ft. It iddles ok, but bog from 1/2 to full throttle, i need to know how do you guys think my jetting is, should i go richer on the main, should i adjust pilot or needle clip?
