After market reeds
99sheee
So did someone with a clue do a drag port on the cyls?  Not knowing any specifics on the motor setup is hard to tell what you'll need.    Strictly drags, you might as well run alcohol. 35-39mm alky Carbs,  intakes, filters,  used will run 300-600.  You'll need better pipes, about 300-500 used.  Post pics of bike so we can see what'll need changed chassis wise.
  • Like 1
What kind of exhaust do you recommend? I can find out anything specific about the motor youd like to know. Its literally a stock chassis besides extended swinger. I plan to  swap to a different chassis eventually. Just trying to get the motor running good now. Ill post a picture shortly
You need to figure out what your port timings are on cylinders.  Compression.  Timing. Etc.  Multiple pipes that work good for drag.  Shearer,cpi,led.  Where will you be racing ? Dirt /sand track , dunes, hill, ?
