SKEETER Posted July 14, 2019 Report Share Posted July 14, 2019 So did someone with a clue do a drag port on the cyls? Not knowing any specifics on the motor setup is hard to tell what you'll need. Strictly drags, you might as well run alcohol. 35-39mm alky Carbs, intakes, filters, used will run 300-600. You'll need better pipes, about 300-500 used. Post pics of bike so we can see what'll need changed chassis wise. 1 Quote Link to comment Share on other sites More sharing options...
99sheee Posted July 14, 2019 Author Report Share Posted July 14, 2019 5 hours ago, SKEETER said: So did someone with a clue do a drag port on the cyls? Not knowing any specifics on the motor setup is hard to tell what you'll need. Strictly drags, you might as well run alcohol. 35-39mm alky Carbs, intakes, filters, used will run 300-600. You'll need better pipes, about 300-500 used. Post pics of bike so we can see what'll need changed chassis What kind of exhaust do you recommend? I can find out anything specific about the motor youd like to know. Its literally a stock chassis besides extended swinger. I plan to swap to a different chassis eventually. Just trying to get the motor running good now. Ill post a picture shortly Quote Link to comment Share on other sites More sharing options...
SKEETER Posted July 15, 2019 Report Share Posted July 15, 2019 You need to figure out what your port timings are on cylinders. Compression. Timing. Etc. Multiple pipes that work good for drag. Shearer,cpi,led. Where will you be racing ? Dirt /sand track , dunes, hill, ? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 15, 2019 Report Share Posted July 15, 2019 What is local guys name? Where are you from?Guess-NC, SC, FL, GA, VA, AL, MI, PA Quote Link to comment Share on other sites More sharing options...
SKEETER Posted July 15, 2019 Report Share Posted July 15, 2019 Put me down fo NC Quote Link to comment Share on other sites More sharing options...
ginger Posted July 15, 2019 Report Share Posted July 15, 2019 i would go atleast dual 35mm if your strictly dragging. Quote Link to comment Share on other sites More sharing options...
99sheee Posted July 16, 2019 Author Report Share Posted July 16, 2019 20 hours ago, n2otoofast4u said: What is local guys name? Where are you from? Guess-NC, SC, FL, GA, VA, AL, MI, PA Ky Quote Link to comment Share on other sites More sharing options...
SKEETER Posted July 16, 2019 Report Share Posted July 16, 2019 Do you know denny? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 16, 2019 Report Share Posted July 16, 2019 Do you know denny?Fuk that theif!Sent from my SAMSUNG-SM-G891A using Tapatalk Quote Link to comment Share on other sites More sharing options...
99sheee Posted July 16, 2019 Author Report Share Posted July 16, 2019 2 hours ago, SKEETER said: Do you know denny? Cant say that i do. Quote Link to comment Share on other sites More sharing options...
SKEETER Posted July 16, 2019 Report Share Posted July 16, 2019 2 hours ago, n2otoofast4u said: Fuk that theif! Sent from my SAMSUNG-SM-G891A using Tapatalk Figured that'd get your attention. ha Quote Link to comment Share on other sites More sharing options...
