C63kay Posted July 5, 2019 Report Share Posted July 5, 2019 Is there anything I should replace remove or add and also what size domes and what size jets should I start off at I run 93 and trail ride. What size swing arm and sprockets should I run I have Yfz suspension, fv4 reeds, cool head. Cylinders - Serval Wampus 421 Hot Rods 4mm Stroker Crank Keihin 35mm PWK Banshee Billet Water Pump Impeller Standard Flow WITH Gasket Oversized Radiator Modded Shift Star Clutch Pancake Bearing Gasket Kit Complete Seal Kit Engine Ice 1/2 Gallon Banshee Heavy Clutch Springs Spark Plug Chop Tool Cool Head Acorn Nuts Yamabond 4 Sealer Timing Plate - Billet Ignition Coil Spark Plug Cap KLG-type Sprocket Lock Washer Lock Washer - Folding - Clutch Nut Stock Rubber Intake Clamp Quote Link to comment Share on other sites More sharing options...
C63kay Posted July 5, 2019 Author Report Share Posted July 5, 2019 All from fast racing Quote Link to comment Share on other sites More sharing options...
Keno Posted July 5, 2019 Report Share Posted July 5, 2019 Ask FAST since that is who you bought it from. But pump gas Servals usually run 24cc domes Ditch the yzf450 suspension, it is a proven bad setup. Get something made for the banshee. Swingarm, probably stock length to +2. Stock gearing. Don't know what the stock rubber clamp means. You will need an aftermarket intake for the pwk35's. Quote Link to comment Share on other sites More sharing options...
C63kay Posted July 5, 2019 Author Report Share Posted July 5, 2019 (edited) 12 minutes ago, Keno said: Ask FAST since that is who you bought it from. But pump gas Servals usually run 24cc domes Ditch the yzf450 suspension, it is a proven bad setup. Get something made for the banshee. Swingarm, probably stock length to +2. Stock gearing. Don't know what the stock rubber clamp means. You will need an aftermarket intake for the pwk35's. Cool also what spark plugs would you recommend I didn’t order yet I’m ordering once I know exactly everything to order hopefully by the end of the day Edited July 5, 2019 by C63kay Quote Link to comment Share on other sites More sharing options...
Keno Posted July 5, 2019 Report Share Posted July 5, 2019 Br8es Quote Link to comment Share on other sites More sharing options...
