New banshee owner
I recently got a new banshee it has Toomey t5 pipes and silencer bored .20 over coolhead k an n pod filters no air box and force Reeds basically I'm just unsure of what kinda gas I should be running the guy I purchased it from said he would mix a can with 2 gallons ethanol free premium and 2 gallons race has with a 16oz bottle of redline oil just curious if that sounds like a good mix
skeet with some actual good advice, bravo.
 if you are at 160 psi you wanna run 100 octane if you are 155 or under you can just run straight premium.  Do you have advanced timing
also fyi some nerd info if you are going to mix octanes  the formula to figure out octane is  A. octane rating (110) x percent mixed (.4) = X (44)   +  B. octane rating (93) x percent mixed (.6) = Y (99.8), Then add the sums of A and B      thats the formula using a standard 5 gallon can.  16 oz of oil with that would be a 40:1 premix ratio
Edited by Ayesully810
  • Like 1
My head is hurting.
Envoyé de mon SM-G965W en utilisant Tapatalk
So I Did a comp test today came out at 140 both cylinders were like the exact same haven't checked timing yet but both cylinders matched so that's a plus so I wonder if I'd be good to just run premium? Or is non ethanol premium better? It seems like i dont need to run race gas and premium like the previous owner said
i wish. i sure hope the premium here is non eth.  apparently if you pour a certain amount of water into gas the ethanol with separate to the bottom and then you can syphon  it out from the bottom, guess it lowers the octane level though idk. saw it in some youtube video prolly saying it wrong
