PaymentPlan Posted June 19, 2019 Report Share Posted June 19, 2019 PM me if interested. Prices do not reflect shipping. Lower rear fender brackets $10 Grab bar rear fender brackets $10 Rear brake pusher and res $15 Precut vent tubing from Cascade Innovations $8 per pack Bulk vent tubing $3 per foot, either size tube. Tubing will ship as one piece so you can cut yourself. - 4 mm I.D. 7 mm O.D. for carburetor vents - 3 mm I.D. 5 mm O.D for the float bowl overflow Honda 400EX thumb throttle housing $30 - Welded additional aluminum so you can open up 39 pwk's. This will need some grinding to finish it and use properly. OEM new right side cover $40 Lower motor tension rods with all hardware $30 Rear brake pedal $15 Dual pingle valve $60 Powder coated YFZ450R front brake calipers $40 - Need new seals and a cleaning Pro design tether $15 Powermadd handguards $30 - Hand guards only, no mounting hardware Pro taper pad cover $5 Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted June 19, 2019 Author Report Share Posted June 19, 2019 Additional pictures can be requested. Sent from my SM-G950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 19, 2019 Report Share Posted June 19, 2019 I’ll take the throttle, pro taper pad cover and hand guards, and enough tubing for 2 sets of carbs. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted June 20, 2019 Author Report Share Posted June 20, 2019 I’ll take the throttle, pro taper pad cover and hand guards, and enough tubing for 2 sets of carbs. 10-4. I'll get you sent out Friday. Sent from my SM-G950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted June 20, 2019 Report Share Posted June 20, 2019 Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted June 20, 2019 Author Report Share Posted June 20, 2019 I texted you some details. Sent from my SM-G950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted June 21, 2019 Author Report Share Posted June 21, 2019 Chromed spindles reamed for LSR arms $75Magnura hydraulic clutch setup $75Sent from my SM-G950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Willysbanshee05 Posted July 30, 2019 Report Share Posted July 30, 2019 Hey the rear brake master cylinder is god condition? How much is shipped to 17522? Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted July 31, 2019 Author Report Share Posted July 31, 2019 9 hours ago, Willysbanshee05 said: Hey the rear brake master cylinder is god condition? How much is shipped to 17522? Rear brake master cylinder is in excellent condition. Shipped to 17522 is $9.50. Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted July 31, 2019 Author Report Share Posted July 31, 2019 To the top Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted August 17, 2019 Author Report Share Posted August 17, 2019 (edited) On 6/19/2019 at 5:00 PM, PaymentPlan said: PM me if interested. Prices do not reflect shipping. Lower rear fender brackets $10 Grab bar rear fender brackets $10 Rear brake pusher and res $15 Precut vent tubing from Cascade Innovations $8 per pack Bulk vent tubing $3 per foot, either size tube. Tubing will ship as one piece so you can cut yourself. - 4 mm I.D. 7 mm O.D. for carburetor vents - 3 mm I.D. 5 mm O.D for the float bowl overflow Honda 400EX thumb throttle housing $30 SOLD - Welded additional aluminum so you can open up 39 pwk's. This will need some grinding to finish it and use properly. SOLD OEM new right side cover $40 Lower motor tension rods with all hardware $30 Rear brake pedal $15 Dual pingle valve $60 Powder coated YFZ450R front brake calipers $40 - Need new seals and a cleaning Pro design tether $15 Powermadd handguards $30 SOLD - Hand guards only, no mounting hardware SOLD Pro taper pad cover $5 SOLD Updated the list. Feel free to make offer on any parts. Edited August 17, 2019 by PaymentPlan Quote Link to comment Share on other sites More sharing options...
Mobilemechanic Posted September 4, 2019 Report Share Posted September 4, 2019 Pingel and hydraulic clutch shipped to 28411 Quote Link to comment Share on other sites More sharing options...
HedgeFundsMoney Posted September 8, 2019 Report Share Posted September 8, 2019 is the hydro clutch still available ? Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted October 11, 2019 Author Report Share Posted October 11, 2019 On 9/8/2019 at 3:45 PM, HedgeFundsMoney said: is the hydro clutch still available ? SOLD Quote Link to comment Share on other sites More sharing options...
PaymentPlan Posted October 11, 2019 Author Report Share Posted October 11, 2019 On 6/19/2019 at 5:00 PM, PaymentPlan said: PM me if interested. Prices do not reflect shipping. Lower rear fender brackets $10 Grab bar rear fender brackets $10 Rear brake pusher and res $15 Precut vent tubing from Cascade Innovations $8 per pack Bulk vent tubing $3 per foot, either size tube. Tubing will ship as one piece so you can cut yourself. - 4 mm I.D. 7 mm O.D. for carburetor vents - 3 mm I.D. 5 mm O.D for the float bowl overflow OEM new right side cover $40 Lower motor tension rods with all hardware $30 Rear brake pedal $15 Dual pingle valve $60 Powder coated YFZ450R front brake calipers $40 - Need new seals and a cleaning Pro design tether $15 Chromed spindles reamed for LSR arms $75 This is the most current list of items available. Quote Link to comment Share on other sites More sharing options...
