Blueshee98 Posted June 3, 2019 Report Posted June 3, 2019 Hey guys just had quick question the mid range on my shee sputters pretty bad especially when hot the needle clip was on the 2nd to the top and I moved it to the first but still sputters a little what should I do? Quote
Keno Posted June 4, 2019 Report Posted June 4, 2019 What carbs? You could change needles to one that is leaner in the mid range, but that only helps if you are rolling into the throttle. You could try a smaller main if you are rich on the top end also. Or just feather/pop the clutch through that section of the rpm range and/or downshift if needed. Quote
Blueshee98 Posted June 4, 2019 Author Report Posted June 4, 2019 Stock carbs and the needle is in the leanest position but top end is perfect Quote
