jabon Posted June 2, 2019 Report Share Posted June 2, 2019 (edited) 465 wampus serval, did a compression test today, one side at 125ish, other side at 100ish, time for a rebuild I would take it ? What should the compression be for this build ? Over 150 i assume, I'm new to the 2 stroke game. I got it for hillclimbing, its loosing power on the easiest hills, it should be eating them. Edited June 2, 2019 by jabon Quote Link to comment Share on other sites More sharing options...
Keno Posted June 4, 2019 Report Share Posted June 4, 2019 Cylinders should be within a few psi of each other. 100 is low. Psi depends on domes, elevation and what porting has been done. I would assume you should be at least 140-150 if set up for pump gas. Probably time for new pistons. Take the top end off and see what condition everything is in. Quote Link to comment Share on other sites More sharing options...
