yamahaman244 Posted June 1, 2019 Report Posted June 1, 2019 (edited) Hey guys my brother recently bought a banshee, it’s suppose to be a 4mil stock cylinder. 155 psi both cylinders 35 pwks with pods t5 exhaust. No timing advance. We are at 1200 ft for elevation isn’t running worth shit. It has a 168 main, 48 pilot and clip on 4th groove. It idles rough and hitting harder on left side. Carbs are synced. I moved clip to middle didn’t make a real difference. Is he that rich on pilot.? I have a 4mil with cpi dune hillshoot port timing plate 190psi 35pwks vforce 4 reeds and I’m at a 155 main 50 pilot needle in the middle and it runs good. Edited June 1, 2019 by yamahaman244 Quote
Larry's Shee Posted June 1, 2019 Report Posted June 1, 2019 It's not logical to compare different set ups, to a point. Even two supposed identical set ups may need different jetting. That being said, have you done a plug chop or plug read? If so, what was the result? Quote
Larry's Shee Posted June 1, 2019 Report Posted June 1, 2019 Lean will act/sound flat. Rich blubber and fart. Quote
yamahaman244 Posted June 1, 2019 Author Report Posted June 1, 2019 Larry I have and it’s deffonly rich on the main. Just trying to get a starting point or as why it’s not idling very good. Now like before the pipe comes on it has a big flat spot but will pull through to the pipe. Only does it if your not Reving it hard. I’m trying to figure out if it’s s rich bog flat spot in midrange or if it’s a lean one. Which way on the middle does what. I get so confused. From the small end that goes into bottom of carb if your raise the clip you lean it out? Quote
dano3 Posted June 1, 2019 Report Posted June 1, 2019 https://static1.squarespace.com/static/5be4d5b35ffd2095efa9bdff/t/5bf1a09b6d2a7391b5a84730/1542561947962/KeihinCarbJetting-2015.pdf This is a good write up for dialing in the pilot jet. If the carbs are synced but one side is hitting harder, might be wise to run a leakdown test too, especially because he just bought it. Quote
