Chopboy Posted May 23, 2019 Report Posted May 23, 2019 2003 banshee will start and run but when it’s warmed up And I shut it off it’s hard to start I have to wait till its cold again Quote
machinegunbanshee Posted May 23, 2019 Report Posted May 23, 2019 Pilot jet too big. what size are you running? Quote
Chopboy Posted May 23, 2019 Author Report Posted May 23, 2019 200 main 27.5 pilot needles 3rd clip 600ft above sea level Quote
Chopboy Posted May 23, 2019 Author Report Posted May 23, 2019 Stock basically t5 tommy exhaust air box no lid 40:1 ratio Quote
gusto Posted May 23, 2019 Report Posted May 23, 2019 Your mains are small. Pilots are right size though Quote
gusto Posted May 23, 2019 Report Posted May 23, 2019 Have a look at the jetting thread and find someone that has a similar set up and compare jetting Quote
Chopboy Posted May 23, 2019 Author Report Posted May 23, 2019 I have 300 mains jets should I use them with the same pilots Quote
gusto Posted May 23, 2019 Report Posted May 23, 2019 You said 200. Anyway drop your main like mentioned earlier Quote
SKEETER Posted May 23, 2019 Report Posted May 23, 2019 Try swapping the 200s for the 300s, see if it does same . Quote
Chopboy Posted May 23, 2019 Author Report Posted May 23, 2019 My bad gusto worded wrong I mean I have a extra pair of 300 mains I can use if need to be Quote
Chopboy Posted May 24, 2019 Author Report Posted May 24, 2019 Alright guys I did put the 300 mains in didn’t change anything but I did find out that the problem was my flywheel key was laying on the inside of the stator and broken and now I have really big Ping marks on the crank😡😡😡 but y’all was helpful thanks Quote
gusto Posted May 24, 2019 Report Posted May 24, 2019 You may have to take it to a machine shop if it’s too badly damaged. At least you know the problem. Quote
