Assorted banshee stuff
Clearing out some stuff i have laying around and dont need. All prices are OBO. Let me know if you want better pictures.
Pwk 33/35 carb bowl modified/welded to clear clutch arm actuator. This will prevent access to mainjet with bowl installed. Got this with a set of carbs but didnt need it with my intakes. Have never checked for leaks but will verify before selling. $20
Clean clutch cover with wear from boot and brake lever. No waterpump-$50. With billet impeller and plastic gear-$75
Welded hotrods 4mm crank. Will require rebuild and new bearings. There is some pitting on the flywheel surface from corrosion between flywheel and crank after lapping but flywheel key never slipped-see pics. $90
