Davidmdx25 Posted May 12, 2019 Author Report Share Posted May 12, 2019 I didn’t think it could be that since I shut it off. It didn’t shut off on its own Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 12, 2019 Report Share Posted May 12, 2019 It kicks over, just won't start when kicked? What are the "new oe cylinders" Yamaha or just not cp? are they niche? Re-check compression now Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Davidmdx25 Posted May 12, 2019 Author Report Share Posted May 12, 2019 Yes it kicks over just won’t start. Yamaha cylinders Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 12, 2019 Report Share Posted May 12, 2019 If it was me , I would do a compression check and pull your pipes and see how scored your new Pistons are on the exhaust side when you do a compression check see how gray your plugs are too How much coolant did you have to put back in it to fill it back up? Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted May 12, 2019 Report Share Posted May 12, 2019 Yamaha and OEM are the same thing. What cylinders did you buy? But yes, do what 375HPB said. Quote Link to comment Share on other sites More sharing options...
Davidmdx25 Posted May 14, 2019 Author Report Share Posted May 14, 2019 Ok so here’s and update. Compression tested 115 on left cylinder and 120 on right. Pulled both spark to make sure I was getting spark and I am. I hit the kill switch to “off” and stopped getting spark. That proved that my kill switch is good. And compression is good. What else can I look for ? Quote Link to comment Share on other sites More sharing options...
coleman66six Posted May 14, 2019 Report Share Posted May 14, 2019 1 hour ago, Davidmdx25 said: Ok so here’s and update. Compression tested 115 on left cylinder and 120 on right. Pulled both spark to make sure I was getting spark and I am. I hit the kill switch to “off” and stopped getting spark. That proved that my kill switch is good. And compression is good. What else can I look for ? Don’t know if you messed with the flywheel side at all but if the flywheel key in the flywheel got chipped or even came out of place it can cause your timing to be way out and it won’t start, had this happen to me with a YZ. Just a suggestion. Quote Link to comment Share on other sites More sharing options...
Davidmdx25 Posted May 15, 2019 Author Report Share Posted May 15, 2019 I have not touched the fly wheel side but I’ll look into it this weekend ! This is so frustrating Quote Link to comment Share on other sites More sharing options...
O.G BHQ MBR FROM 2000 ? Posted May 15, 2019 Report Share Posted May 15, 2019 (edited) When you rebuilt the top end did you inspect the reed pedals on the reed cages? The reeds pedals could be worn out or have chips missing or they disintegrated from age. Edited May 15, 2019 by O.G BHQ MBR FROM 2000 ? Quote Link to comment Share on other sites More sharing options...
Davidmdx25 Posted May 23, 2019 Author Report Share Posted May 23, 2019 Yea I checked them when I did the top end. There was a tiny bit of light through one of the pedals so I unscrewed it and flipped it upside down to try and close the gap. However, there was still a very small gap. But it ran fine for a bit that’s what I don’t understand Quote Link to comment Share on other sites More sharing options...
O.G BHQ MBR FROM 2000 ? Posted May 23, 2019 Report Share Posted May 23, 2019 Ok, You can give this a try. Get yourself a spray bottle and put some of your premixed fuel you use and put it in the spray bottle and remove the filter or filters and hold the throttle wide open and spray into The carbs and then release the throttle and then try kicking it over and see if that works. Quote Link to comment Share on other sites More sharing options...
Davidmdx25 Posted May 25, 2019 Author Report Share Posted May 25, 2019 (edited) Ok so here’s an update. i put my premix in an empty water bottle and poked a small hole through the lid. WOT I squeezed a bit in on both carbs. Sounded like it wanted to start but didn’t. I squeezed a little bit more in and BOOM! Started up. Got on it and it would almost have intermittent power. It would pick up and then kinda loose all power, then try to pick up but then loose power again and so on... then it bogged out and wouldn’t start by just kicking it. It was on for a total of about 3 minutes Edited May 25, 2019 by Davidmdx25 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 25, 2019 Report Share Posted May 25, 2019 This the only time it's tried to start?Need to find out why it's not getting fuel... Cap not venting, float level off, fuel screen clogged, jets clogged...Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted May 25, 2019 Report Share Posted May 25, 2019 Have you tried starting it before? you should find out why its not getting fuel. The cap is not venting possibly, perhaps the float level is off. It is also possible the jets are clogged. Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 25, 2019 Report Share Posted May 25, 2019 14 minutes ago, Ayesully810 said: Have you tried starting it before? you should find out why its not getting fuel. The cap is not venting possibly, perhaps the float level is off. It is also possible the jets are clogged. Sent from my XT1585 using Tapatalk I know that Tyler's pic was a little shocking for you but, put down the flip phone, grab your smartphone again ,so you won't be delayed and repeating a post Sent from my XT1585 using Tapatalk Quote Link to comment Share on other sites More sharing options...
