solobanshee Posted May 10, 2019 Report Posted May 10, 2019 Just recently got some Vito's Performance 28mm carbs, uses Keihin style jets. Just wondering what jet size I should start off with?? Mods: FMF Gold series pipes 28mm Vito's Carbs No air box, K&N Pods Fuel Mixture: 32:1 Altitude: 40ft (basically sea level) Temperature: In Northern CA so right now its 80-90 , I don't plan on riding in anything over 90 degrees. winters can get down to 50 degrees Thanks!!!!!! Quote
Ayesully810 Posted May 11, 2019 Report Posted May 11, 2019 23 hours ago, solobanshee said: Just recently got some Vito's Performance 28mm carbs, uses Keihin style jets. Just wondering what jet size I should start off with?? Mods: FMF Gold series pipes 28mm Vito's Carbs No air box, K&N Pods Fuel Mixture: 32:1 Altitude: 40ft (basically sea level) Temperature: In Northern CA so right now its 80-90 , I don't plan on riding in anything over 90 degrees. winters can get down to 50 degrees Thanks!!!!!! vitos 28mm carbs?? post up a pic im curious of what kind of carbs you got from them. Quote
