Need help jetting my 04 banshee 34mm carbs. Set up is 19cc domes cool heads, 66mm pistons,stock cylinders dune port, stock crank, timing on plus 4, vforce4 reeds aluminum intake, again 34mm flat side carbs and I'm at sea level any help please??
23 hours ago, Ayesully810 said:
what is it doing? is it running poorly ? or is this a first start up
what jets does it have currently
Update to your question I've ran the heat cycles 3 full cycles  its running lazy and sluggish  at take off. I'm running 175 mains and 45 pilots any suggestions
19 hours ago, 2strokenojoke said:
Mostly when trying to lunch
where is your needle clip at? does it hesitate to make power? like sputtering before it starts making power? and yes main seems big but if it revs right now at wot id address the sluggishness,
