jeremyshee01 Posted May 5, 2019 Report Share Posted May 5, 2019 If you guys had to choose between the mr501 or a set of tires with every other row cut off which would it be? Most of the competitions are not like the ones tyler clarke competed in, they're sorta like a 1000 ft semi-steep incline that u could take a warrior up easily or something like that. Some are up grassy ski slopes racing 4 or 5 wide and others are on semi loose dirt like you would find say in the woods. Also with those that say the 501's, would u cut those too or do people run them like they are? Tia Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 5, 2019 Report Share Posted May 5, 2019 The cut tires will still work best. CST Ambush is still the best cut tire. Nothing has changed. I’ve seen a couple new hillclimb bike builds on FB recently that are almost identical copies to stuff I was doing in 2012. Quote Link to comment Share on other sites More sharing options...
jeremyshee01 Posted May 5, 2019 Author Report Share Posted May 5, 2019 That's awesome, I'm staring at a new set as we speak. Bought them n hate the front tires so they stayed on only a week. And I laughed a little, I'm trying to copy u as we speak lol. Quote Link to comment Share on other sites More sharing options...
Paulie B Posted May 6, 2019 Report Share Posted May 6, 2019 I'd like to see someone try goldspeed sc4's with every other row cut. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 6, 2019 Report Share Posted May 6, 2019 I'd like to see someone try goldspeed sc4's with every other row cut.I have a set cut and ready to go. I don’t see any way they’ll be as effective as Ambush for several reasons. Knowing what I know, I’d pick the Ambush if I only had one run at the hill. Quote Link to comment Share on other sites More sharing options...
Paulie B Posted May 6, 2019 Report Share Posted May 6, 2019 You wont run them. I check out some pics of those cat ambush tires. They look like standard razor knock offs. I dont doubt you because you know but why are they so dominant? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 6, 2019 Report Share Posted May 6, 2019 You wont run them. I check out some pics of those cat ambush tires. They look like standard razor knock offs. I dont doubt you because you know but why are they so dominant?There’s a lot of differences. The only free info I’m giving out is that I run Ambush. I’ve tested cut Razors. They don’t work. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 17, 2019 Report Share Posted May 17, 2019 When you see the ambush tires with lower air pressure, they wrinkle up like drag slicks. The side wall on them was well thought out. That's where the extra traction is at. The Maxxixs Razr won't flex anywhere near what the Ambush does. 1 Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 18, 2019 Report Share Posted May 18, 2019 ^ free 1 Quote Link to comment Share on other sites More sharing options...
Pinkylee Posted June 29, 2019 Report Share Posted June 29, 2019 Has anyone tried tractor bar tires ? Just curious, cause I am currently in the process of building my first banshee. Which will be used mostly for woods and hill climbing, and that is what I use on my rail buggy. NOTHING beats them for hill climbing on buggies. Personally I use a skinnier set than most, and I make it up more stuff than most. My theory is... Skinnier tire equals more weight per square inch for traction..Seems to work GREAT for ME...Sent from my LG-H700 using Tapatalk Quote Link to comment Share on other sites More sharing options...
