Chopboy Posted April 17, 2019 Report Share Posted April 17, 2019 Banshee poping on right side Quote Link to comment Share on other sites More sharing options...
gusto Posted April 17, 2019 Report Share Posted April 17, 2019 Check spark check compression check your plug caps report back Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 17, 2019 Author Report Share Posted April 17, 2019 Compression is 120 on both sides I’m bout 600ft above sea level tommy t5 exhaust basically a stock banshee 300 main 27.5 pilots Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 17, 2019 Report Share Posted April 17, 2019 Will it start and idle at all? If it will idle, while its running, spray some carb cleaner around your intake boots, cylinder base gasket, reeds, etc. Listen for a bog or rev while you are spraying. You could have an air leak. You can also try swapping plug caps side to side and see if the problem jumps to the other cylinder. Swap reeds, intake boots, etc. Pull the carbs off and give them a good cleaning just for safe measure. You can unplug your stator wires and check resistance across the different coils and make sure that is all within spec. Failing stators can cause some weird issues like that sometimes, so its worth checking and is pretty easy to do. Quote Link to comment Share on other sites More sharing options...
gusto Posted April 17, 2019 Report Share Posted April 17, 2019 ^^^^this bigred350x, hows your build going? Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 17, 2019 Author Report Share Posted April 17, 2019 I cleaned carbs about ten times I used a rebuild kit put them back together put new spark plugs gap to 28 to 32 mm I checked stator, pickup coil, running 93 pump gas with Castro’s 927 premix @40:1 check reeds no cracks no daylight coming in. Boots good on carbs plugs caps good. Carbs are synced good the best I can see Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted April 17, 2019 Report Share Posted April 17, 2019 how does it run? does it break up at all in the rpms as you get into the powerband Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 17, 2019 Author Report Share Posted April 17, 2019 When it’s was running it run good I was riding and I ran out gas heard a pop it died took it hom tryed to start nothing pulled carbs cleaned them now it’s hard to start kick it like 50times nothing and I have tried all the settings on the carbs I know Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 17, 2019 Report Share Posted April 17, 2019 Jump time? Check crank key? Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 17, 2019 Author Report Share Posted April 17, 2019 Ok I will do that waiting on flywheel puller I ordered. Thanks Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 17, 2019 Report Share Posted April 17, 2019 It's got spark & fuel ? Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 17, 2019 Author Report Share Posted April 17, 2019 Rite so the timing off then rite? Quote Link to comment Share on other sites More sharing options...
gusto Posted April 18, 2019 Report Share Posted April 18, 2019 How old is the top end and how good is your compression tester? no air leak ? with the reeds out how do the pistons look? Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted April 18, 2019 Report Share Posted April 18, 2019 (edited) you said its hard to kick? as in turn over. if it were me id inspect all moving parts now, start with easiest to access to more difficult. stator cover, to pulling head off, then clutch cover. could have smoke the pick up coil and its stuck to the fly wheel had that happen before with a tight gap when i was younger my first banshee made a loud pop too and then wouldnt run right, blew the rings out of the one side. Edited April 18, 2019 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
Chopboy Posted April 18, 2019 Author Report Share Posted April 18, 2019 Bosch tester and and have to take a look at topend now when I do what am I’m looking for on the pistons Quote Link to comment Share on other sites More sharing options...
