Rollinunknown Posted December 11, 2003 Report Share Posted December 11, 2003 Hey any ways i bought some NGK iradirum (SP?) plugs for my work advanced auto parts... are thease good plugs to run in my banshee? its all stock 2004 im hopeing to get mods ASAP !.. Quote Link to comment Share on other sites More sharing options...
boonman Posted December 11, 2003 Report Share Posted December 11, 2003 B8ES or a B9ES. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 11, 2003 Report Share Posted December 11, 2003 i run B8EV. never had any problems with them. ive always been told that with a more hopped up engine that a hotter plug will make it run better. just what ive heard, im not an expert or anything. Quote Link to comment Share on other sites More sharing options...
raxen Posted December 12, 2003 Report Share Posted December 12, 2003 B8ES Quote Link to comment Share on other sites More sharing options...
xelerated Posted December 12, 2003 Report Share Posted December 12, 2003 Now, how come noone is running B"R"8ES? I thought you HAVE to run Resistor plugs with Dig. ignition? Yamaha even calls for it? If you guys aren't running "R" plugs, why??? Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted December 12, 2003 Report Share Posted December 12, 2003 thoes plugs are good plugs to run they are a finer point probably burn the fuel more efectivly Quote Link to comment Share on other sites More sharing options...
94BansheeRider Posted December 14, 2003 Report Share Posted December 14, 2003 I believe they took the place of the EVX series, which were platinum tips. The Iridium is supposed to be better. But they cost $$$. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted December 14, 2003 Report Share Posted December 14, 2003 I haven't never noticed any difference between the BR8es and B8es plugs... Quote Link to comment Share on other sites More sharing options...
2001SSTBanshee Posted December 18, 2003 Report Share Posted December 18, 2003 The difference is one has a resistor and one doesn't. "R" Quote Link to comment Share on other sites More sharing options...
fixitrod Posted December 18, 2003 Report Share Posted December 18, 2003 Ngk plugs seem to not foul as easily. I don't know about different models. Here's my theory on ignition though. If there is a good spark, fuel will fire. All this better point, split fire....blah blah blah. If you have any quality plug and it fires there's going to be an explosion. If you don't believe me try this Stand in a room full of gas. Light a lighter and a torch. I bet both rooms blow up the same height considering they have the same amount of fuel and air. Just a theory though. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted December 18, 2003 Report Share Posted December 18, 2003 The difference is one has a resistor and one doesn't. "R" yea I know. I mean THey both perform the same, at one point I was running one of each in my cylinders and there was still no difference.. I would however like to find out what the difference is between the Brass threaded NGK's and the aluminum threaded NGK's I hear the brass colored ones don't fowl as easy, but again I have run one of each without noticing a difference? Quote Link to comment Share on other sites More sharing options...
xelerated Posted December 19, 2003 Report Share Posted December 19, 2003 Rod- That is KILLIN me! Im still laughing!!!!! Quote Link to comment Share on other sites More sharing options...
