shee97 Posted April 15, 2019 Report Share Posted April 15, 2019 hey guys so i purchased my first shee and it was running good i notice i was leaking a little fuel now my right side carb is leaking fuel and my exhaust is spitting out oil from the exhaust to silencer need help Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 15, 2019 Report Share Posted April 15, 2019 Check your float height in the carbs, check bowl gasket on the carbs. On the leaking pipes, take the silencer off, and check the seal where the stinger tube meets the silencer. I do t remember what the T5s had for a seal there. Some have a press-fit, some have an oring, etc. Dont be afraid to tear into it,these things are pretty simple. Do you have stock air box or pod filters? Tors deleted on the stock carbs? Might be easy to chase down the leak or might be a pain depending on how much stock garbage is on the carbs. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted April 15, 2019 Report Share Posted April 15, 2019 If its where the expansion chamber meets your silencer stinger, lots of companies sell those seals they are cheap. Just replace it. Quote Link to comment Share on other sites More sharing options...
Toybreaker Posted April 21, 2019 Report Share Posted April 21, 2019 There is a little "valve" in the body of your carbs that have a rubber insert on them. they wear out. You need to replace the needle and seat for the fuel inlet on your carbs. Don't just do 1.... you are going to have it apart anyway do them both. Quote Link to comment Share on other sites More sharing options...
