??? Crank seal
if you have a crank seal leak in the right side (clutch side) you will smoke like a train out the right side, it wont rev, and you will have oil (transmission) coming out the silencer depending on how bad the leak is.  its more obvious if its a crank seal leak.  did you pressure test the motor after rebuild to find any leaks? you might have small leaks around the intakes which is nbd but the crank seals are a no no on leaks.  if so and that tested out, then check float level, perhaps the left side isnt getting fuel
