Lockout clutch HELP!
When the fingers are lower at idle or part throttle the clutch plate will push the lower rounded part of fingers out slightly when you pull the lever. Then as you get in to throttle the top rounded part of the fingers make contact with the pressure plate to add lock up force.
In your drawing with three different ways it could touch the pressure plate, definitely like #1 or #2. They definitely get squirlly when it’s so far out like #3.
  • 2 years later...
