Banshee626 Posted March 12, 2019 Report Share Posted March 12, 2019 Fresh build 4mil long rods wiseco pistons pro circuit pipes k&n filter stock filter tray no lid stock carbs (IMO) the problem Quote Link to comment Share on other sites More sharing options...
97Screamer Posted March 12, 2019 Report Share Posted March 12, 2019 Stock carbs are not the problem, more than enough to support what you've listed. Sounds like a jetting issue. Quote Link to comment Share on other sites More sharing options...
Banshee626 Posted March 12, 2019 Author Report Share Posted March 12, 2019 Is it really and what I meant to put is stock carbs with stock jets and pilots Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted March 12, 2019 Report Share Posted March 12, 2019 You need bigger jets than stock Quote Link to comment Share on other sites More sharing options...
Banshee626 Posted March 12, 2019 Author Report Share Posted March 12, 2019 You know more or less what size jets will be alright with my setup...thanx for the info by the way been breaking my head over This damm bike these past weeks Quote Link to comment Share on other sites More sharing options...
Banshee626 Posted March 12, 2019 Author Report Share Posted March 12, 2019 How come on neutral it revs out nice and high I know it’s a stupid thing to do but I did notice I could rev the hell out of it but as soon as it’s in gear and under load just sputtering away first gear goes okay 2-6th gear just sputtering don’t even hit the powerband Quote Link to comment Share on other sites More sharing options...
SKEETER Posted March 12, 2019 Report Share Posted March 12, 2019 Pull carbs, clean thoroughly, get jet sizes, report back. Also, might check your stator and ohm it , make sure it's up to par Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted March 12, 2019 Report Share Posted March 12, 2019 (edited) stock jets and pilots are absolutely the issue lol toomey or vitos needle should be what your using a 32.5 pilot or 35 should then dial in the air fuel screw accordingly 320 to 340 main im assuming you have porting with increased compression as well as that factors in to jetting. if not those are good starting points but will probably need less fuel if no porting or compression/timing Edited March 12, 2019 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
SKEETER Posted March 12, 2019 Report Share Posted March 12, 2019 32.5-35 pilot, 320-340 main ?? Just curious why you think it needs that much fuel Quote Link to comment Share on other sites More sharing options...
SKEETER Posted March 12, 2019 Report Share Posted March 12, 2019 My dune port, 4mm with 170psi , +5 timing ,stock carbs only needed 30 pilots, 290 mains, Toomey needle in middle. At 1000ft- and sea level. Quote Link to comment Share on other sites More sharing options...
Banshee626 Posted March 12, 2019 Author Report Share Posted March 12, 2019 I cleaned the carbs lowered the needle position all that good stuff so I’m thinking jetting too I swapped stator and coils from my other bike and I was about to try the cdi but never did Anyone know where I could get a jet kit... thanx 4 the feedback fellas.. Quote Link to comment Share on other sites More sharing options...
gusto Posted March 12, 2019 Report Share Posted March 12, 2019 My 4 mil with PC ran 27.5 pilot and 320 main Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted March 13, 2019 Report Share Posted March 13, 2019 (edited) 3 hours ago, Ayesully810 said: 3 hours ago, SKEETER said: 32.5-35 pilot, 320-340 main ?? Just curious why you think it needs that much fuel i doubt it will. i said starting points and also stated it will probably need less fuel. just wanted to over estimate since he has been abusing it on stock jets. if there is no porting or advancement or compression those are def embellished numbers my 4 mil driveline motor was a 37.5 pilot and 360 main on pump gas. ive yet to see a motor that needs as much pilot as mine did though. Edited March 13, 2019 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
Banshee626 Posted March 14, 2019 Author Report Share Posted March 14, 2019 anyone know where I can get a jetting kit and can I still run the (tors) or is it better to remove Quote Link to comment Share on other sites More sharing options...
mercury65 Posted March 15, 2019 Report Share Posted March 15, 2019 you can run your tors. and you can get a jet kit from toomy they have the better needle's. with a stock motor with t5 pipes at sea level is 290-300 and those numbers are right from toomy . if you use the toomy instructions ( found on web site) it will help you. Quote Link to comment Share on other sites More sharing options...
