Can’t quite get a whole lotta jetting info on these carbs, just looking for a ballpark to get me started.
V force4 reeds, Pro Circuit pipes, stock head, stock bore, elevation is 1100ft ASL ambient temp the bike would be run in is 10 to 30 degrees Celsius
ive never jetted 28s before but i have quite a bit experience with 35s
a 45 pilot and 145 ish main sounds about right for starts   maybe less main if its really humid. this might be on the rich side.    jjh needles are most used with success with 28s.  get pilot set first so its start and idles good then get main figured out, work needle last middle clip should be good to start.
Edited by Ayesully810
All of the PWK carbs will jet similarly.
For that elevation and temp, I would start with 165 main and 50 pilot.. Then work from there.
I've had everything from 33 to 41 PWK and they all jet similarly on a wide range of motors.
The same ones recommended. JJH needles. Pilots probably somewhere between 45 and 50. Main somewhere between 145 and 165.
Start big and work down.
  • 2 weeks later...
Prefect ! Got 155 mains and a 50 pilots and seemed to get me really close thanks loco !
