Thatonedude304 Posted March 6, 2019 Report Share Posted March 6, 2019 I have tons of play in my shifter. Where should I start as far as troubleshooting ? thanks Quote Link to comment Share on other sites More sharing options...
kawa110 Posted March 6, 2019 Report Share Posted March 6, 2019 With a Clymer book.Most likely behind the clutch cover. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 7, 2019 Report Share Posted March 7, 2019 Pull the clutch cover. Look at the shifter shaft that passes from the Stator side of the motor to the clutch side. It wraps around the shift star. If you can wiggle the claw on the end it’s time to replace it. Also, check the bushings it rides in. Pretty rare that those go bad, but it does happen. While you’re at it, inspect all of the shifting components like the star, eccentric screw, and detent arm. Quote Link to comment Share on other sites More sharing options...
Thatonedude304 Posted March 7, 2019 Author Report Share Posted March 7, 2019 Does the crankcase have to come apart to replace the shaft? I'm recently jumping back into owning a banshee after a 12 year break so it's been a while.. thanks for any info Quote Link to comment Share on other sites More sharing options...
SKEETER Posted March 7, 2019 Report Share Posted March 7, 2019 No. Just remove clutch cover Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 8, 2019 Report Share Posted March 8, 2019 No need to split the cases. Just loosen the bolt to remove the shift lever. The whole shift shaft assembly will slide out the clutch side. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted March 8, 2019 Report Share Posted March 8, 2019 clutch basket needs to be removed Quote Link to comment Share on other sites More sharing options...
