Ok so I was thinking of jumping to 32 mm carbs with a cool head and dg exhaust.. as of now with stock carbs, dg exhaust and boost bottle and I am running main jet 220 and a 20 pilot. How will I have to jet it for the bigger carbs? Will I need to use the same jets or go bigger
Can I ask why you think going to 32s is a good idea? Properly setup stock carbs will be a better running bike IMO.  You don't need bigger carbs
Do a comparison,  even after porting.  You'll like the stock carbs better.  Hope that's an OEM stator your putting on.
