Need help loss of power
So I went riding this weekend at sandlake in Oregon and when I'm pinning it for more then like 15 seconds the bike just looses all power like I turned the bike off and I have to pull the clutch in rev it a bit then it's fine again. Any reason this could be happening?
5 hours ago, Canadianshee said:
What modifications have you done to the bike or was done to the bike, pipes,carbs jetting, pipes, porting Could be a range of things
Sent from my LG-H873 using Tapatalk
From my knowledge all that was done to it was toomey t5 pipes and a Toomey air filter and porting done by Oregon Motorsports I believe
17 minutes ago, Canadianshee said:
What do the plugs look like, what jet's are in the carbs. When was the bike last running well, was there a large elevation change where you were riding.
Has brand new plugs, no idea what jets it has, bike didn't do this about 2 rides ago so probably 5 hours of engine time ago and no elevation change sea level everytime.
On 3/4/2019 at 1:28 PM, SKEETER said:
Well, my advice would be to pull carbs off, and get jet sizes, few of us live in orygun and know what that motor will need at sandlake, florence, etc.
I cleaned the carbs today there was literally sand inside the jets so that isn't good.. I'm gonna use air filter oil next time and the jets are 290s idk if I just fixed my problem I won't know till I go riding next but my left carb pours gas out of the over flow when I turn the gas on and I have to turn the gas off then back on again and it's fine not sure what this means
Let me give you something to look for.  I bought mine new from dealer rode it one time then put on the Toomey t5 kit all was good, 4 weekends later the motor locked up. as I pulled it apart I started finding sand within.  long story short the stock air filter foam ring rolled up at the bottom as the filter was slid down into the air box that was the last time the stock box was on my shee
6 minutes ago, Jeffyjeff said:
Try lowering the gap on the spark plug and see if that helps at all
good idea, pull the plug, check jetting, had plugs back out at dunes once when it was jetted too lean, started to close the gap even. this was after back to back drag racing at a strip.  more fuel cleared it up
