Banshee802 Posted February 24, 2019 Report Share Posted February 24, 2019 Ok so I’m trying to make my own harness. I have a stator, cdi, ignition coil, and tether that I’m trying to wire up. I’m planning on relocating the cdi behind the gas tank so that the stator can plug directly in. I have a wiring diagram just a little hard to figure out all the grounds. I know the the orange wire from coil goes into cdi along with black and black/white for tether/kill switch. I’m not sure where the black from stator and black from coil go. Trying to make something similar to picture. Help is appreciated, thanks! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 24, 2019 Report Share Posted February 24, 2019 1 Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted March 3, 2019 Author Report Share Posted March 3, 2019 Thanks for that diagram. Couple questions though. The black wire coming off the stator doesn’t go anywhere? I thought it has to get grounded. Why is there only one wire for kill switch. My tether has 2 wires coming off it. Could you explain the grounding? Red/black and black from gray plug get spliced into negative wire that goes to coil or? Thanks!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted March 3, 2019 Report Share Posted March 3, 2019 Black and yellow wire off the Stator are should be the lighting circuit. Typically the kill switch has one wire that hooks to the electrical at the coil, and the second wire will go to a ground on the frame. Quote Link to comment Share on other sites More sharing options...
