stunter01 Posted January 29, 2019 Report Posted January 29, 2019 Im on 5000 ft have a fresh built 421 serval built with vf4 and keihin 36 carbs. They send me 17 cc domes with the kit. I get 175psi when i kick it over. Is this too much pressure im running on pump gas 95 oct. My squise is about 0.9mm. Want to use this bike for the dunes so if i go to sea level must i change the domes ? Sorry maybe this had been discussed before. Please help i dont want to break my engine these parts are very expensive Thanks Quote
375hp banshees Posted January 29, 2019 Report Posted January 29, 2019 Don't run 17 @ sea level! Don't know if i'd only run 95@ 175 either. squish is on the tight side Whatever you do , DONOT ask your Builder Quote
gusto Posted January 29, 2019 Report Posted January 29, 2019 I’ve got new 18cc domes and lightly used 21 cc domes I will sell if your interested. Quote
stunter01 Posted January 29, 2019 Author Report Posted January 29, 2019 Thanks for the reply i also thought to rather fit 21cc. Will buy them from you anytime but im in south africa lol Quote
97Screamer Posted January 29, 2019 Report Posted January 29, 2019 I would run at least 100 octane at 175psi, possibly higher with timing. Yes you will need to change domes to run at sea level. Quote
gusto Posted January 29, 2019 Report Posted January 29, 2019 (edited) 4 hours ago, stunter01 said: Thanks for the reply i also thought to rather fit 21cc. Will buy them from you anytime but im in south africa lol If you pay the shipping I will send them anywhere. PM if you want them i wouldnt run it with 100 octane I would go higher. Paying for race gas sucks, set it up for pump gas Edited January 29, 2019 by gusto Quote
stunter01 Posted January 30, 2019 Author Report Posted January 30, 2019 Thanks screamer im just riding it in at the moment just going low rpms. I was looking for a compression indication for pressure ratings on these oversize cylinders with different dome sizes but couldnt find. I forgot to mention i am on +4 deg also Thanks gusto i found 21 cc domes locally was the last set . But maybe in the future i ll press your button 👍 Quote
Schweet97Z Posted January 30, 2019 Report Posted January 30, 2019 What’s the highest octane you can get at the pump? I’m willing to bet we are dealing with the Ron/R+M/2 conversions here. Meaning his octane level isn’t really 95 like we would consider in the states but more like a 90-91Sent from my iPhone using Tapatalk Quote
ClaudeMachining Posted January 30, 2019 Report Posted January 30, 2019 100LL is a good alternative to race gas.Envoyé de mon SM-G965W en utilisant Tapatalk Quote
stunter01 Posted January 30, 2019 Author Report Posted January 30, 2019 I think you are right it says 95 oct but could be a lot lower Please tell me about your set ups , would love to get an idea Which way i must go. At the moment im on 145 mains not sure about the size of the pilots but will check this weekend think they are to big . Bike was idling fine but when i test it the one side was running out of fuel so i adjusted both float levels and now the idling is worse than before. Would it be a good idea to fit a pringle double outlet valve? Thanks again for all the information Quote
Schweet97Z Posted January 30, 2019 Report Posted January 30, 2019 What’s your elevation? Is 95 the highest octane you can get? On pump gas and advanced timing like that I’d go with a 22-23cc dome depending on your elevation. I’d suggest a dual pingle so you don’t run your bowls dry as well. Sent from my iPhone using Tapatalk Quote
stunter01 Posted January 31, 2019 Author Report Posted January 31, 2019 Rode it yesterday after i adjusted the floats again . Elevation 5000 ft Im on 145 mains at the moment going to fit 21cc domes over the weekend and check my pilot size because after the float adjustment the bike struggles to idle. Also need to fit a pingle i think. After that ill do a plug chop. It feels little dead on higher rpm Quote
trickedcarbine Posted February 18, 2019 Report Posted February 18, 2019 You’ll want 21-22 cc domes for that fuel. Quote
stunter01 Posted March 4, 2019 Author Report Posted March 4, 2019 I couldnt find only got 20cc will fit them over the weekend and check compression Quote
