DetroitDuner Posted January 21, 2019 Report Share Posted January 21, 2019 So all my friends have banshees and we have a tradition of racing every year. Rules currently are stock stroke bikes, that’s it! my mods are: -Trail port -cool head -timing plate +4 - boysen reeds -.060 wiseco pistons -FMF gnarley pipes -stock carbs Dilemma: I plan on stepping up to a better pipe this year because my FMF pipes get walked on HARD up top from my boys t5. Adding shearers. Real world experience should I have My cylinders re-ported like a aggressive dune port/rebuild at the same time? Or should I bite The bullet and buy a big bore kit? The driveline kit is around 850 and a rebuild/port job would be at least 700 I’d say so what’s my best route? Quote Link to comment Share on other sites More sharing options...
DetroitDuner Posted January 21, 2019 Author Report Share Posted January 21, 2019 22 minutes ago, DetroitDuner said: So all my friends have banshees and we have a tradition of racing every year. Rules currently are stock stroke bikes, that’s it! my mods are: -Trail port -cool head -timing plate +4 - boysen reeds -.060 wiseco pistons -FMF gnarley pipes -stock carbs -k&n pods -hotrods crank welded Dilemma: I plan on stepping up to a better pipe this year because my FMF pipes get walked on HARD up top from my boys t5. Adding shearers. Real world experience should I have My cylinders re-ported like a aggressive dune port/rebuild at the same time? Or should I bite The bullet and buy a big bore kit? The driveline kit is around 850 and a rebuild/port job would be at least 700 I’d say so what’s my best route? Also have welded crank and k&n pods Quote Link to comment Share on other sites More sharing options...
SandSlingerOR Posted January 21, 2019 Report Share Posted January 21, 2019 You could just step up to bigger carbs and run the sheare's, that would be enough I'd say. On your current set up. Your bud once you'll beat him, will go with more hp after he gets beat, then you'll want more after he builds a better set up. Quote Link to comment Share on other sites More sharing options...
pp13bnos Posted January 21, 2019 Report Share Posted January 21, 2019 Could throw some V4s in also.. Quote Link to comment Share on other sites More sharing options...
gusto Posted January 21, 2019 Report Share Posted January 21, 2019 DriveLine all the way. Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted January 21, 2019 Report Share Posted January 21, 2019 14 hours ago, DetroitDuner said: Dilemma: I plan on stepping up to a better pipe this year because my FMF pipes get walked on HARD up top from my boys t5. If you and your boys have the same mods but they have T5 and you are getting walked HARD, your boys are better at drag racing. FMF fatties to T5 make similar power and curves that their banshee is not going to be pulling away hard, should be close. Quote Link to comment Share on other sites More sharing options...
DetroitDuner Posted January 21, 2019 Author Report Share Posted January 21, 2019 1 hour ago, ZillaFreak said: If you and your boys have the same mods but they have T5 and you are getting walked HARD, your boys are better at drag racing. FMF fatties to T5 make similar power and curves that their banshee is not going to be pulling away hard, should be close. It’s not that crazy, one of us has CPI and he pulls the hardest... Quote Link to comment Share on other sites More sharing options...
