120 compression after new top end
Ladle58
I'm sure this has been discussed many times over here.  Not finding what I'm looking for though after rummaging through the forums. (I'm also a newbie)
.020 over bore by reputable company and fitted to new weisco pistons and rings. Installed very carefully myself and proper break in.  Leak down test performed.  Still getting between 115 and 120 on both sides. Seems to run fine but wanting to know what I'm missing. If I had to question anything I did it would maybe be the leak down test as I made my own tester. Wondering also if a leak somewhere on the bottom would cause lower compression?
Any help as to where to go from here would be greatly appreciated!
Thanks for the input guys.  That is the exact path I was heading down.  Originally, was just going to ride as is. That being said, I'm not the type of person that can relax and enjoy the ride if I feel something isn't right. Plan was to perform a better leak down test and do a plug chop. So glad to hear someone conquers.  Any other input on this topic will be appreciated.
When you repeat leakdown just make sure it hold 6psi for about 6 min if not spray around with soapy water to find leak.
When i did mine I could not find the leak, but ended up being a leak on pressure gauge. So check your equipment too.
Sent from my LG-H873 using Tapatalk
Well if you want to make sure.
Build a better tester for pressue testing. And retest. 6 psi for 6 min. If it dosen't, check all your fittings and spay motor with soapy water to find leak.
Make sure you are using the correct end for your compression tester, must be same length as the spark plug goes in. Hold throttle wide open and kick till neddles does not move
Did retourqe everything after heat cycle.
With a stock head at sea level your compression should be 120psi. What head/domes are you using and what is your elevation? Most of the flex hose compression testers have shorter threads than your plug and in my experience read 5-7psi low. You'll need to get an adapter that threads in as far as the plug for an accurate reading but I usually don't bother to even get mine out of the drawer. No, an air leak will not impact on your compression unless its huge.
Stock head. I am 750 feet above sea level.
So leak down test is good to do for peace of mind but not for compression since if I have a leak, its small.
Really good chance you are fine. 120 is a good stock number for 750'
Do a leak down, it wont hurt.
But I think you are okay.
Sent from my SAMSUNG-SM-G891A using Tapatalk
