MPDano Posted December 14, 2018 Report Share Posted December 14, 2018 I can't seem to find a part number in the parts diagram I have found online. I need the 2 bolts that hold the swingarm to the rear hub. Previous owner removed them to remove the chain and never put them back on. Anyone got a good diagram with a part number? I am assuming they are both the same. Quote Link to comment Share on other sites More sharing options...
97Screamer Posted December 14, 2018 Report Share Posted December 14, 2018 36 minutes ago, MPDano said: I can't seem to find a part number in the parts diagram I have found online. I need the 2 bolts that hold the swingarm to the rear hub. Previous owner removed them to remove the chain and never put them back on. Anyone got a good diagram with a part number? I am assuming they are both the same. https://www.partzilla.com/catalog/yamaha/atv/2002/banshee-yfz350p/rear-wheel What year is your bike? If its an a-arm those should be the part numbers. If its a j-arm I believe they use a different attachment. I have a complete swingarm/carrier that has a set on there and might have another spare set if you don't find what you need. Quote Link to comment Share on other sites More sharing options...
MPDano Posted December 14, 2018 Author Report Share Posted December 14, 2018 1987. I ended up seeing a thread with bolt size and pitch but no lengths. I measured out 20mm in length and just ordered some off eBay. I'll see how it goes from there. I'll hit you up if they aren't right and just have some more spare bolts. Can't have enough of bolts laying around, lol. After looking at your diagram, I bet it's that long bolt n washer #29 and #30, but it also looks like a long spacer in between that isn't there on mine. Ah, I see this diagram is for a 2002, I looked at 1987 and it's different, doesn't even have a diagram for the rear wheel. Quote Link to comment Share on other sites More sharing options...
97Screamer Posted December 14, 2018 Report Share Posted December 14, 2018 You are correct that an 87 will use different hardware than what I posted. I'm not familiar with the particular hardware the 87s use. Worst case scenario you can upgrade to the newer swingarm/carrier design and hardware but I'm sure you'll be able to find bolts that will work. Quote Link to comment Share on other sites More sharing options...
MPDano Posted December 18, 2018 Author Report Share Posted December 18, 2018 (edited) FYI, got the bolts and they fit perfectly. The chart was correct on pitch, just needed the length which is 20mm on the 87's. Also bought some new plugs and verified there is spark. Just waiting on the carb rebuild kits and replacing hoses and I'm gonna try and fire this bad boy up. Edited December 18, 2018 by MPDano Quote Link to comment Share on other sites More sharing options...
