Play axle prices
Canada
8 hours ago, Canada said:
Thanks for the spacer info 375, so wider is rotor side correct
I ordered a 14/45 setup for hills, and 15t for more open areas is that sound ok
Although the 15t dont fit my case saver, but it might fit my upp unit.
Correct...on my jj&a
your sprocket hub isn't a solid round mount is it. So you can't feed sprocket off, is it?
Ok so thenew 40mm carrier seemed a bit big but i got it in by sanding off the paint on the id of the laegers swing arm
Is this normal i messured the carrier and it seemed like it was 1mm bigger is that even a thing, either way it in ther now and the axle fit and looks great
Just waiting on another sprocket because a dumb ebay vender sent me the 87-88 style unit even thow the add says on the title banshee 90-01, just to warn you
I neend a bigger chain to as im going with slightly lower gearing for hill climbing
Thanks for your help so far.
