421 Serval 100LL
MrKayak350
What's up Banshee fam!
What size domes and timing would you recommend for a setup like this,
421 Serval dune port --> currently running 24cc 100LL 7*
Sniper inframes
33pwks (can't remember jetting at the moment)
VF4's
yada yada yada
Originally had it on 91 pump gas with 4*
Thanks in advance!
If you dont raise the compression, you doenst need 100LL.
100LL is safe to about 165lbs static comp, so i "guess" 22-23cc can get you there.
What's the static compression with your 24cc?? About 140???
Envoyé de mon SM-G965W en utilisant Tapatalk
My tuner said with a higher timing the 100LL would work just fine with these domes. Given my squish .050", I'll be okay but I think it would be safer to run smaller domes right?
Sent from my SM-G960U using Tapatalk
I was running my 421 Serval on 21cc Domes, 0.055" squish, a 1:1 ratio of 91 and 100ll, and using curve 3 on a Dynatek, which is 15* at 10-12K rpm (similar to +6).  Elevation 1500ft.  Didn't have any deto.  I forget what my static compression was, though.
Currently running 91 octane on 24cc domes, 0.045" squish and 13* at 10-12K (similar to +4)  I honestly haven't bothered checking comp on this setup.
These setups used Shearer SBIF and PWK 35s.
Hopefully this helps a little
  • Like 1
0.050 is on the safe side for sure.
What is your static compression with 24cc???
Claude, just checked compression. left side 163, right side 170.
