Aftermarket Radiator
dttuner
This is as close as I can get on the top mount near the handlebars.... wtf.
Am I missing some adapter bracket or something?
Bottom bolts are threaded-in but very loose, and all hoses connected.
Do I just drill a hole to line it up, insert bolt, and say VAFFANCULO!
21 minutes ago, kawa110 said:
I’ve installed 3 as well....
2 lined up perfect...
3rd was just like yours
I rat tail filed the holes to fit....I came to resolution the steering hoop was slightly bent.
Steering hoop bent was my guess. I've got a torch works and an Asi. Fitment was the exact same.
45 minutes ago, ZillaFreak said:
I had a similar issue.
Put top bolt in first.
Then put side ones in and tighten down.
Tried every combination. Doesn't fit. I got the 1 in 100 duds. Almost an inch off center.
My luck
Edited by dttuner
Next put 2 side bolts in loosely to the mount.
Ok, that worked :)
Just hope my plastics line-up...
are those frame mount brackets self-aligning? Like some hidden tab I'm not seeing?
Edited by dttuner
