ClaudeMachining Posted November 26, 2018 Report Share Posted November 26, 2018 Fuck, i still have them lol!!!Didnt know they were not needed.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 28, 2018 Author Report Share Posted November 28, 2018 What else should I replace while I have the clutch case open? - Shifter Star - Shifter star detent - Water impeller ? Quote Link to comment Share on other sites More sharing options...
ZillaFreak Posted November 28, 2018 Report Share Posted November 28, 2018 5 minutes ago, dttuner said: What else should I replace while I have the clutch case open? - Shifter Star - Shifter star detent - Water impeller ? Modded shift star is nice. No need to replace the detent arm. Check eccentric screw. Check the kicker and rebuild if rattling. Check seal and bearing for clutch push lever. Check water pump assembly. Pancake bearing should be installed. Also check clutch cable. Quote Link to comment Share on other sites More sharing options...
kawa110 Posted November 28, 2018 Report Share Posted November 28, 2018 Pancake pusher/ceramic ball Quote Link to comment Share on other sites More sharing options...
97Screamer Posted November 28, 2018 Report Share Posted November 28, 2018 Billet water pump drive gear Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted November 28, 2018 Report Share Posted November 28, 2018 On 11/26/2018 at 12:45 PM, n2otoofast4u said: On 11/26/2018 at 12:26 PM, dttuner said: Yeah? More trouble then they worth? I won't install them, but just curious as-to the history of these little buggers... and how the fugg did I have 2 in there? 30 years ago someone thought they were needed. They are not. Right in the trash is where they go. They ARE needed if you want to "shock the clutch"... but.. that's just a "hairflip"... Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted November 28, 2018 Report Share Posted November 28, 2018 They ARE needed if you want to "shock the clutch"... but.. that's just a "hairflip"...Can you elaborate??Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 (edited) On 11/18/2018 at 10:19 AM, locogato11283 said: You should check the clutch basket for play while you’re in there. It might need cushions. Thanks for putting this seed into my head. And thanks to South Texas Banshee. Your vids are the shit brother. Realized I didnt check the basket play correctly last time... and sure enough my cushions are shot... Guess I'm doing cushions and billet water impeller while Im at it. Thought the shee would live again by this weekend. Guess not. Edited November 30, 2018 by dttuner Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 On 11/28/2018 at 2:44 PM, kawa110 said: Pancake pusher/ceramic ball Isn't this only needed if you're an asshole and don't maintain your banshee properly... aka no oil / shitty oil? Quote Link to comment Share on other sites More sharing options...
kawa110 Posted November 30, 2018 Report Share Posted November 30, 2018 Needed for those who don’t want to weld the ball to pushrod. Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 On 11/28/2018 at 2:43 PM, ZillaFreak said: Modded shift star is nice. No need to replace the detent arm. Check eccentric screw. Check the kicker and rebuild if rattling. Check seal and bearing for clutch push lever. Check water pump assembly. Pancake bearing should be installed. Also check clutch cable. Nice list dude. I'll find videos on how to properly check this stuff. 2nd pancake bearing recommendation. 100% needed huh? Okay. Kicker rebuild is already done. I'm also replacing all brake pads and brake fluid, removing parking brake and replace with billet piece, oem headlight fixes and vinyl covers, exhaust clamps/polish and possibly redo the packing material, right rear tire leak, new engineice, new redline 75w gear oil for clutch, new billet levers and perch, grease cables, new spark plugs, straightened plastics, polishing the rear axle, cleaning the PRO filter... My wishlist if funds show-up: - suspension - radiator - led lights - 6 pack rack Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 3 minutes ago, kawa110 said: Needed for those who don’t want to weld the ball to pushrod. done. nuff' said. Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 10 minutes ago, kawa110 said: Needed for those who don’t want to weld the ball to pushrod. done. nuff' said. Adding Water pump, pancake bearing, and maybe shifter star. Quote Link to comment Share on other sites More sharing options...
dttuner Posted November 30, 2018 Author Report Share Posted November 30, 2018 $115 for Impeller, Bearing, Seal, Pancake bushing and gasket?https://www.ebay.com/itm/Banshee-Pancake-Bearing-And-Billet-Water-Pump-Rebuild-Kit/142596287133?hash=item213366aa9d:g:jf0AAOSwXrdaF3OD:rk:25:pf:0 Quote Link to comment Share on other sites More sharing options...
97Screamer Posted November 30, 2018 Report Share Posted November 30, 2018 MacDaddy sells good stuff, I wouldn't hesitate to buy. Quote Link to comment Share on other sites More sharing options...
