Amsoil
johngolfvr6
The Amsoil 100to1 synthetic oil can be used in 50to1 , 80to1 or 100to1
the 50to1 and 80to1 ratios should be used in high horsepower and high rpm applications.
You can fine tune the ratio for your application.
We have tried them all and banshee's seem to like the 80to1 ratio .
The series 2000 racing oil is designed for modified high performance engines with extended rpm range and high compression , Hence the name racing oil.
Recomended ratio of 50to1 is recomended.
Dyno testing with this oil concluded 50to1 was optimal ratio for minumum high temperature torque loss.
I have used this oil in all my two strokes since day one.
