Banshee802 Posted September 29, 2018 Report Share Posted September 29, 2018 Alright guys, so I bought a stainless steel clutch cover and stator cover bolt kit. All the clutch bolts went in find and all. But on the stator cover only like 2 bolts actually bolt down the cover. The rest of the bolts seem like they bottom out before even touching the plastic stator cover. Could this be because the bolts are too long? Has anyone ran into this problem before?? Thanks Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
booxzzy Posted September 29, 2018 Report Share Posted September 29, 2018 You sure you didn't mix them up, cause I think there is 2 or 3 different lengths on stator side. Sent from my ONEPLUS A3000 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 You sure you didn't mix them up, cause I think there is 2 or 3 different lengths on stator side. Sent from my ONEPLUS A3000 using Tapatalk102% positive I didn’t mess it up. There are 3 very long bolts all same size and like 5 short bolts again same size. There’s no way the longer bolts could go anywhere else besides the stator cover. However they bottom out before the bolt head touches.Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
booxzzy Posted September 29, 2018 Report Share Posted September 29, 2018 102% positive I didn’t mess it up. There are 3 very long bolts all same size and like 5 short bolts again same size. There’s no way the longer bolts could go anywhere else besides the stator cover. However they bottom out before the bolt head touches.Sent from my iPhone using TapatalkThen they must've messed up, sent couple of mm longer than they should. Try cutting them and taper the tip with grinder if you can't be bothered retaining. Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Then they must've messed up, sent couple of mm longer than they should. Try cutting them and taper the tip with grinder if you can't be bothered retaining. Sent from my ONEPLUS A3000 using TapatalkCool. Just my luck lol. Do you happen to have any of the bolts lying around to quickly tell me the proper length? Thanks!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Also these are the ones I boughthttps://www.ebay.com/i/271997206044?chn=ps&ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.com%25252Fi%25252F271997206044%25253Fchn%25253Dps%2526itemid%253D271997206044%2526targetid%253D474173634149%2526device%253Dm%2526adtype%253Dpla%2526googleloc%253D9003091%2526poi%253D%2526campaignid%253D1481359801%2526adgroupid%253D56517111999%2526rlsatarget%253Dpla-474173634149%2526abcId%253D1139296%2526merchantid%253D101691871%2526pt%253D%2526gclid%253DEAIaIQobChMIm9K00abf3QIVkY-zCh0fXQ94EAQYAiABEgKT3fD_BwE%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1684968988252%2526rvr_ts%253D236f7be31660ab6badf45de1fff5d571Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted September 29, 2018 Report Share Posted September 29, 2018 I have them on my bench and can tell you tomorrow morning 1 Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 I have them on my bench and can tell you tomorrow morning Ight. Thanks man. My banshee isn’t liking this colder weather and the flywheel is starting to rust. Want to get this motor buttoned up lolSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
booxzzy Posted September 29, 2018 Report Share Posted September 29, 2018 Then they must've messed up, sent couple of mm longer than they should. Try cutting them and taper the tip with grinder if you can't be bothered retaining. Sent from my ONEPLUS A3000 using TapatalkReturning not retaining lolSent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
dano3 Posted September 29, 2018 Report Share Posted September 29, 2018 Warshers then leakdown Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
JUSTWANNARACE Posted September 29, 2018 Report Share Posted September 29, 2018 Have you blown out the holes? Stock bolts are a little shorter and will get dirt behind them. Also do you have the rubber gasket on the cover? Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Warshers then leakdown Sent from my iPhone using TapatalkWhat?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Have you blown out the holes? Stock bolts are a little shorter and will get dirt behind them. Also do you have the rubber gasket on the cover? Sprayed some wd40 in the holes and cleaned out the threads with a q tip. The bolt is going all the way in and bottoming out on the inside. I do have the rubber gasket onSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted September 29, 2018 Report Share Posted September 29, 2018 Short ones are exactly an inch long 2.5 inches Quote Link to comment Share on other sites More sharing options...
Banshee802 Posted September 29, 2018 Author Report Share Posted September 29, 2018 Short ones are exactly an inch long 2.5 inchesIs that from the head? My short ones measure 1.01 from the head and long ones 2.6 from head. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
