120mm or 115mm rod on 10DM? Piston info?
as a general rule your better off with the longer one. it goes back to the friction loss thing between long and short. but for availabilty reasons you may be forced to use the short one, if the long one is rare and hard to find. with the longer one there may  also be a small benefit from the lower primary compression ratio depending if u have a rather high ratio now. longer one may also be structurally stronger since longer rods are typically used in larger capacity engines. some of this is speculation as i dont know anything about your engine or 120 rods. i like the idea of the longer one, if for nothing else but the friction standpoint but i know some hard to find rods can be 200-$300 each
110 rod would b fine for a while also. imo theres a big difference between being fine and being perfectly reliable for many years.  people forget that often times your using larger heavier piston, doubling the power and increasing rpm 2000-3000 more rpm. maybe claude could put the numbers in his nifty FEA program and show how the shorter stockish rods compare to longer beefier stuff
even if u could show the shorter ones revs a bit faster, i think its kind of a weak argument in the big picture but thats just me
