Ayesully810 Posted September 17, 2018 Report Share Posted September 17, 2018 (edited) Ive had an issue that has happened twice now. After i got my tranny back from tyson it has been great, pro mod was a good choice for me. But, a while back I noticed i couldnt find neutral anymore and was hanging on some gears, so naturally i thought the eccentric screw needed adjusting, wrong. I took everything off and the shift star screw came out along with the dowel pin and the star came way out of alignment. I put the dowel pin and screw back in tighten it up and this past ride same thing happened. My question is , how the hell do you tighten that screw down hard enough so it dont come out? can I put in it first gear ( so the drum wont turn) and use a 20v drill to hammer it down a tad? whats the best way to do it aside from splitting the cases. Edited September 17, 2018 by Ayesully810 Quote Link to comment Share on other sites More sharing options...
97Screamer Posted September 17, 2018 Report Share Posted September 17, 2018 Impact = bad news. Clean the oil off really good and use red loctite. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 17, 2018 Author Report Share Posted September 17, 2018 (edited) 7 minutes ago, 97Screamer said: Impact = bad news. Clean the oil off really good and use red loctite. will do, i used blue. i think i need red Edited September 17, 2018 by Ayesully810 1 Quote Link to comment Share on other sites More sharing options...
booxzzy Posted September 18, 2018 Report Share Posted September 18, 2018 will do, i used blue. i think i need redUse brake cleaner, it get things really clean fast Sent from my ONEPLUS A3000 using Tapatalk Quote Link to comment Share on other sites More sharing options...
87sheerips Posted September 18, 2018 Report Share Posted September 18, 2018 Shred gnar bro Quote Link to comment Share on other sites More sharing options...
ginger Posted September 18, 2018 Report Share Posted September 18, 2018 wrong page JD lol Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 18, 2018 Author Report Share Posted September 18, 2018 lol jd you goof, i wanna start mountain biking though looks fun. anyways. i used a crap ton of blue not red, pretty sure it ant coming out because i tried to screw it out and couldnt get it to budge. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 21, 2018 Report Share Posted September 21, 2018 As stated above, blow the threads out with some carb cleaner or brake cleaner, clean the little screw real good too. If you have had issues with it in the past, I would just go for the red loctite. I've never had one back out with using a small dab of blue loctite on there. If it happens again, maybe order a new screw. Perhaps the threads are just a little worn or out of spec. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 21, 2018 Author Report Share Posted September 21, 2018 7 hours ago, BigRed350x said: As stated above, blow the threads out with some carb cleaner or brake cleaner, clean the little screw real good too. If you have had issues with it in the past, I would just go for the red loctite. I've never had one back out with using a small dab of blue loctite on there. If it happens again, maybe order a new screw. Perhaps the threads are just a little worn or out of spec. yeah thats a good thought, if it comes again its getting the red stuff. I really tried to back it out by hand hte other day with a bit of strength on it and it wouldnt move. i know the 7 vibrates more, but it should stay put now Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 22, 2018 Report Share Posted September 22, 2018 All else fails just weld it in. hahahaha Quote Link to comment Share on other sites More sharing options...
Keno Posted September 22, 2018 Report Share Posted September 22, 2018 I'm a big fan of loctite 243. Its an oil insensitive blue threadlocker. But yeah, spray the area down with brake clean. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 22, 2018 Author Report Share Posted September 22, 2018 21 minutes ago, BigRed350x said: All else fails just weld it in. hahahaha not like i plan on using a different shift star on it ! haha Quote Link to comment Share on other sites More sharing options...
