BigRed350x Posted September 15, 2018 Author Report Share Posted September 15, 2018 Never was much of a fan of the arched look. I always liked them straight. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 15, 2018 Author Report Share Posted September 15, 2018 Well, got the banshee home and started to tear into it. 1989 model. Frame is in great shape, no bends or cracks anywhere. Came with a 2into1 intake and a 39mm pwk carb and a set of 28pwk's with intakes and filters. FMF pipes in great shape. Pulled the engine for a tear down. It looks like it has a brand new top end and brand new cylinders, but im pretty sure they are those cheap chinese knockoff cylinders. Pistons had no markings at all. The head gasket was a really thin flimsy piece of sheetmetal. Definitely not stock. Are those cylinders any good or just toss em? Cases have never been port matched or anything. As far as i can tell so far its pretty unmolested. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 15, 2018 Report Share Posted September 15, 2018 out of the box yes they are junk but they can be cleaned up to make it run right idk about how optimal though, but a cheap fix in the right hands from what ive read (with good pistons) i wouldnt run them, but also if your planning on this being a bigger motor like a 10 or something and you arent going to run those 28s a guy in the FS section is looking might be able to help fund your build. pics?? Quote Link to comment Share on other sites More sharing options...
registered user Posted September 15, 2018 Report Share Posted September 15, 2018 those knockoff cylinders are kind of junky . the machining may not be very good and sleeve might not be straight. if u have porting tools u should b able to clean them up and theyll b usable Quote Link to comment Share on other sites More sharing options...
gusto Posted September 15, 2018 Report Share Posted September 15, 2018 PM me on carbs if your selling. sounds like a good start. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 18, 2018 Author Report Share Posted September 18, 2018 On 9/14/2018 at 8:32 PM, registered user said: those knockoff cylinders are kind of junky . the machining may not be very good and sleeve might not be straight. if u have porting tools u should b able to clean them up and theyll b usable Good info. I have some older basic porting stuff in a box somewhere. I would probably have to order some new bits and stuff for them. I'll probably just toss them in a box and go with an aftermarket cylinder. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 21, 2018 Author Report Share Posted September 21, 2018 Here's a few pics. Split the cases last night. Lots of old goo in there. Still had the original clutch from yamaha from back in 1989. I don't think the cases had ever been opened up. At least I know anything that gets F'd up at this point is my fault. LoL Everything else looked to be in really good shape for its age. No deep grooves in the clutch basket, idler gear was still tight on the shaft, stock shift star, shift segment adjustment eccentric bolt didn't show any wear.... Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted September 21, 2018 Author Report Share Posted September 21, 2018 Not bad for $1000. Came with plastics, gas tank, seat in good condition (only 1 small tear about an inch long)... Still not too sure about the knock-off cylinders and those pistons though. The little red thing in the cases was just the straw from my carb cleaner can that popped off as I was spraying some stuff off. Quote Link to comment Share on other sites More sharing options...
gusto Posted September 21, 2018 Report Share Posted September 21, 2018 How much HP you going for? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted September 21, 2018 Report Share Posted September 21, 2018 If you go 10mill, you'll probably need new cases.Envoyé de mon SM-G965W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
registered user Posted September 21, 2018 Report Share Posted September 21, 2018 pistons look new and could probly be reused if clearances r good. knockoff cyl should b fine. theyre just a bit ruff around the edges. sleeve windows likely dont match very well to the casting windows but that can be fixed with porting tools Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 21, 2018 Report Share Posted September 21, 2018 4 hours ago, ClaudeMachining said: If you go 10mill, you'll probably need new cases. Envoyé de mon SM-G965W en utilisant Tapatalk umm why?? Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted September 21, 2018 Report Share Posted September 21, 2018 33 minutes ago, Ayesully810 said: umm why?? Some builders want to work on new cases. Quote Link to comment Share on other sites More sharing options...
Ayesully810 Posted September 21, 2018 Report Share Posted September 21, 2018 10 minutes ago, ClaudeMachining said: Some builders want to work on new cases. sounds like a waste of money to me. if i took my cases to someone and wanted to have em trenched and they wouldnt because they werent new, id send em some where else 1 Quote Link to comment Share on other sites More sharing options...
gusto Posted September 21, 2018 Report Share Posted September 21, 2018 (edited) 100%^^^ Edited September 21, 2018 by gusto 1 Quote Link to comment Share on other sites More sharing options...
