Water Pump
sand rocket
I drained the antifrez(sp) the other day. Today i was cleaning the cover for the water impeller and notice that it has a grooved circle in it. When i looked at the impeller there is also groves in it. And looks to be warped, one side has a flat spot it were it could have been rubbing on the case. Any reason as to why it would have been rubbing?
Were is the cheapest place to get the pro design impeller?
There will be a circular pattern rub mark on the case, that is normal. Look at the impeller in bright light and see if there are tiny cracks in it. If you have the side cover off the motor do the same with the gear. You can buy a new one if you want, but if it's not overheated and the plastic is good, you're probably just fine.
